فهد أمير
Nov 1
Looking for recommendations for a good dash cam. Also, I noticed that wiring can be quite a hassle. Could any expert help with issues related to power supply and wiring? Thanks a lot! 🌹
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
I just got the 2021 luxury version of the GV80. I'm wondering if I need to apply a front windshield film and window film. Also, for a dash cam, which type can be hidden without needing wiring? Looking for some expert advice.
How about adding an aftermarket sound system? Any recommendations? Also, what about dash cams?
4I used to drive a Ford Focus, and now I'm driving an Outlander. The Outlander is smooth on flat roads, but there's a noticeable lag when accelerating. The Focus would respond immediately when I stepped on the gas, and the steering was precise. The Outlander's steering feels a bit heavy, and when going uphill, it makes a lot of noise but doesn't move much. Even if I increase the throttle, the engine noise is quite loud.
5I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
6After 8 years with my old petrol car, it started burning oil, and I noticed a lot of people around me were switching to electric vehicles. That got me thinking. I was originally planning to get the top-spec Tank 300 (Menglong), and during the National Day holiday I went for a test drive — it met my expectations.On the way back, I stopped by a Jetour dealership and saw the T2. My daughter instantly fell in love with the exterior and interior — it completely overshadowed the Menglong in her eyes. Looks clearly played a big role, and after a test drive, it felt good enough. Since I don’t really need 4WD for daily driving, I booked it right away. Looking back now, I do wish I had waited for the 4WD version — a bit more power would’ve been nice.For this type of vehicle, electric power saves a lot. For daily use, my cost is just around 0.10 AED/km (charging at home on off-peak rates of 3.3 AED/kWh). My daily round-trip to work is under 20 km, so I only charge every four days, when the battery hits around 20%.For long-distance trips, I don’t bother with charging — it’s too much hassle. I just set the car to preserve 60% battery and drive on petrol. Even if fuel consumption is slightly higher, it’s fine since I only do a few road trips per year.The car is heavy and feels solid on the road. Acceleration is decent, but the 4WD version definitely would’ve offered better power and confidence. I’ve had the car for over half a year now. So far, the only issue has been a slight noise from the steering system — which was fixed. Other than that, no major problems. Buying a car always involves a bit of luck anyway.The biggest downside is the driver assistance system — it lags behind the competition. The infotainment system has improved a bit with the latest 4.11 update, but it still has room for improvement.Overall, I’m quite satisfied. Compared to many newer EV startups, Chery is an established brand. The lifetime warranty adds a lot of peace of mind, especially on the powertrain and electric components.
7To be honest, I didn’t buy the Corolla out of strong conviction at first. Back in April, I quickly bought a used car from the local market before the Eid holidays. Turned out to be a total disaster. I was in a rush and didn’t have time to go to a mechanic or deal with any hassle, so I drove it for a bit, sold it, and moved on. After that, I decided I wanted to buy something brand new, something I could stick with for 10 years without any headaches. I liked the look of both the Civic and the Corolla. I went to check them out, and while the Civic was really impressive, it was a bit too expensive—so I settled on the Corolla. Overall, the car is smooth and comfortable to drive. But when you're on an incline or waiting at a light on an uphill road, you can feel it struggle to get going—you have to press the gas harder, and the engine gets louder without the car really moving much. The front seats are good, but the rear bench isn’t very spacious. I was honestly disappointed to find that the rear seats don’t fold down, so if you want to carry large items, you’re out of luck. As for fuel consumption—those people claiming 5L/100km, I honestly don’t know how they’re getting that. In the city, I’ve been getting around 6.8 to 7.2, and I’m not a heavy-footed driver. From February 2 to early April, I drove about 4,600 km because I was using it for errands after work and even took a long round trip to Alexandria. One thing I really noticed is that the car doesn’t handle rough roads well—you really feel the bumps. In traffic, sometimes the car shakes a bit when moving slowly around 10 or 15 km/h—not always, but it happens. There's also a faint squeaking noise, like the A/C button is slightly loose—it only shows up on bumpy roads. Still, none of this changes the fact that the car is generally reliable and stable. It drives easily, and honestly, I’m quite content with it—especially after what I went through with that used car. For anyone thinking about getting a Corolla, just be realistic about what you’re looking for. It’s a great car for someone who wants something long-lasting, even if there are a few things that aren’t perfect.
