فهد أمير
2024-08-02 08:21
Just asking for advice. Fellow car enthusiasts, does the CX30's tire easily get bulges like the 18-inch rims on the Mazda3? How about its fuel consumption and maintenance costs? Which configuration would you recommend? Is the fabric seat a good choice? Is it recommended to get the sunroof version? Any issues with leaking? Is the maintenance troublesome later on? Thanks.
Comments( 7 )
حسين نور دين
حسين نور دين2024-10-08 22:17
The premium version of the GWM 30 comes with a 55% aspect ratio, which is much thicker compared to the 40% aspect ratio of the Mazda3. Fuel consumption is around 6-7 liters for pure gasoline, 8-9 liters in heavy traffic, and 10 liters in temperatures below zero. It's better to drive an extra 5 kilometers than to be stuck in traffic for 10 minutes; it has typical American car characteristics. If you change the oil yourself, the maintenance cost isn't high, and you can even use some high-quality oil. The fabric seats are excellent. There's no need for a sunroof. If you can drive a manual, always opt for a manual transmission. It's rare to find a car like the GWM 6 with such a responsive factory-set RPM drop. If you really want a 360-degree view, consider the top configuration. The low-end version has a tail light with a circle, while the high-end version adds a horizontal line. You can't see the lights while driving anyway, so it's not a big deal.
حسن جم
حسن جم2024-09-13 08:33
The 18-inch tires on the Mazda Axela are too thin; 30 would be a bit thicker.
جمال الدين سلمان
جمال الدين سلمان2024-09-09 19:49
The aspect ratio is there, a bulge is impossible. Speaking of manual transmission, buying a Mazda3 is not as good as the -30. This one is a 2.0-liter, you can totally think of it as a slightly bulkier hatchback version of the Mazda3. I'm ready to make the purchase.
فهد مصطفى
فهد مصطفى2024-08-03 19:34
Mazda 3 with the same configuration is about ten thousand cheaper.
شادي نايف
شادي نايف2024-08-03 19:31
No regrets, the top choice in its class, and the manual version is truly unique.
فهد أمير
فهد أمير2024-08-02 08:48
Hello fellow car enthusiasts, does the CX30 have different tail lights for each configuration like the Mazda3, or do they all have round tail lights? Or are the lower trims the narrow-eyed ones?
فهد أمير
فهد أمير2024-08-02 08:23
I'm a bit torn between buying the Mazda3 or the CX-30, sigh.
Hey GV80 owners, I want to know if opting for the 22-inch rims makes the tire sidewalls too thin, leading to potential bulging issues? I really like this car and am considering getting one.
With a budget of around 100, you are looking for a 992s with four-wheel drive, in white with a red interior or in silver. At this price range, you might be able to find a used car in decent condition. The exact condition will depend on factors such as mileage, year of manufacture, and maintenance history. It's recommended to check the service record and perhaps get a professional inspection before purchasing to ensure the car's quality.
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
I've been driving a Touran for 7 years, and it's time for a change. I'm looking for recommendations based on my needs. Here's what I'm looking for: I commute 25km one way to work, and there's no fixed parking spot in my community. The city is crowded, which tests my driving skills, so the car can't be too big. I'd like a space for a nap at noon, so electric or plug-in hybrids are preferred. We are a family of three, and we often take the kid out on weekends, so the car's stability and smooth driving are important as my family gets car sick easily. I often take care of the kid alone, and since the kid is not very strong, an electric sliding door would be great. My kid likes camping in the car, so it needs to have ample space. Occasionally, I need to move things between houses, so flexible space is a plus. Since my wife doesn't drive, we can only have one car. Right now, it seems like the GAC E8 is the only option 🤣
Don't rush to buy this car just yet; wait for three to four months as a new model will be released. The 2025 model will come out early next year. People are interested in this car mainly because of its zero fire risk and sincere configuration. Be prepared for the following if you decide to purchase this car: 1. The overall electricity consumption is over 20, and it might be even higher for men driving it, considering the car weighs 2 tons. 2. The car has severe nose diving when you brake, causing it to wobble a few times. 3. The sound insulation is poor; you need to close the doors with force, and dust easily gets inside the car. 4. Repair parts are as expensive as those for Mercedes-Benz and BMW. 5. The seats, while known as "Nissan Big Sofas," are not as comfortable as those in the Sylphy. 6. There are quite a few minor issues and faults, with the car's system being a significant drawback.
Mazda Mazda CX30
Mazda CX30AED 95,000 ~ 100,500Gasoline
