If you're planning to change the oil yourself, what size socket do you need for the oil filter?
How many liters of oil does a 1.5T engine need to be changed? Is it easy to do it yourself?
Hello everyone, when doing a minor maintenance on the Toyota Tundra, do you need to remove the skid plate to change the oil filter and drain the used oil? Or does the skid plate have an inspection port for changing the oil filter and draining the oil? I'm worried that if you have to remove the skid plate every time, it might wear out the threads on the original car frame, especially since some workers use electric tools for tightening.
How many liters of transmission oil does a Smart 4-door need for a change? Do I need to remove the oil pan and replace the filter?
4What engine oil and oil filter are you all using? What's the price range you're going for? Thanks, everyone!
5What size socket do I need for the bolts on the 2009 Yuexiang wheel? Is it 19mm? Thanks everyone. 🙏
6Do I need to remove the oil pan to change the oil?
7Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
8Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
9Guys, can you buy a spare tire for the 2008 model and put it in yourself? Will it fit?! What size should you get?
10If you're planning to replace the LED lights on a 2013 Kia Sportage yourself, you'll need to know the specific model of the LED lights required. It’s best to consult the vehicle's manual or check the existing LED bulbs for their specifications.
