عبدالرحمن بهاء
2024-10-12 22:32
Consulting everyone, if I change my manual 30 to high-end 18-inch wheels, do I need to modify the brake discs and calipers?
حسين حمد
حسين حمد2024-10-17 09:11
There's nothing much to change about the 18-inch ones; they're ugly. The 16-inch ones look better with a deeper color. You don't need to change the brakes when switching, it just looks uncoordinated and too spaced out.
عبد العزيز عمر
عبد العزيز عمر2024-10-16 12:47
16-inch tires are more durable and practical compared to 18-inch ones. With the 18-inch tires on the JAC J7, I have to be careful about the roads I take, worried about a blowout.
جمال الدين سلمان
جمال الدين سلمان2024-10-15 11:09
Have you finished the modification? Can you provide a reference image? [thumbs up]
حرب سعود
حرب سعود2024-10-15 09:02
No need to change, the ET value is always 45.
خالد بدر الدين
خالد بدر الدين2024-10-13 00:36
As long as you're happy... Is this your first time buying a car?
Hey folks, has anyone modified the foot brake parking? I'm thinking of making some changes.
You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
Hey guys, I just got my Es2000 recently, and there's a clunking noise when I brake. It seems to be coming from the brake calipers. Do any of you have the same issue?
Does anyone know the specs for this 22-inch rim? I want to modify this car.
Has any car owner modified the headlights? I asked at the shop and they said it needs to be changed to 16 lenses, 8 for low beam and 16 for high beam. I haven't seen any examples of such work, so I didn't dare to modify it easily. [Facepalm]
Is the brake caliper on the sports kit version of the Haval model red or black? I saw online that it's red, so why is mine black?
I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
Did you get your brake pads and brake discs replaced at the 4S shop? How's the quality? I just got mine changed today for 2500 RMB.
Mazda Mazda CX30
Mazda CX30AED 95,000 ~ 100,500Gasoline
