زايد علي
2024-02-14 17:54
With a budget under 200,000 and needing a 7-seater SUV for a family with two kids, you're looking for something safe, stable, spacious, and reliable. Considering Changan CS95 and Exeed Lingyue, which one is more recommended?
Comments( 15 )
خالد احمد
خالد احمد2024-02-23 07:05
GS8, wake up!!
نايف جواد
نايف جواد2024-02-22 21:38
Not worth it at all.
عمر يونس
عمر يونس2024-02-18 19:40
Just take your family to the dealership to check out the two cars. When I was buying a car, the GWM Tank 500, Haval H9, and Geely Xingyue L were all options for me. In the end, I took my family to experience them all and see which one they liked.
عبد العزيز جليل
عبد العزيز جليل2024-02-17 23:44
Safety is definitely assured with the GWM Tank 500, as certified by CCTV.
محمد لطيف
محمد لطيف2024-02-17 00:48
I drive a first-generation 95, and it's currently at 230,000 kilometers. As long as I do regular maintenance, it's good to go. It doesn't picky with fuel or engine oil. I've only changed the tires and timing belt, nothing else. In terms of power and the four-wheel drive system, it outperforms the Exeed!
مسعود عمر
مسعود عمر2024-02-16 23:19
With a budget of 200,000, you have options like the Hyundai Santa Fe and Ford Territory as a base, and then models like the Haval H9, GWM Tank 500, VW ID.6 Crozz/X, and Chevrolet Blazer—all offering 6-7 seat configurations. The Crown 95 is indeed considered an older model.
أحمد أكبر
أحمد أكبر2024-02-16 17:32
Custo, if you're not in a hurry, wait until the end of the year for the Tucson and the new Santa Fe.
عمر عيسى
عمر عيسى2024-02-16 00:20
The Haval Moon is definitely a no-brainer choice. Whether it's design, power, fuel economy, or safety, it absolutely outperforms the 95.
حسين عباد
حسين عباد2024-02-15 22:43
Definitely the Lanshan!
أحمد دل
أحمد دل2024-02-15 16:00
The value retention of the 95 isn't great. I've studied the 95 since its first generation and really like it. The four-wheel drive is powerful, even though it's an on-demand system, it's truly impressive. However, some aspects are a bit outdated, and the fuel consumption is high. Although I really like the 95, the Haval Dargo is also good. In the end, I just want to say that everyone has their own preferences, and what you like is the best choice for you.
Maintenance guide for the 2007 Opel Astra: 1. **Regular Oil Changes**: Ensure you change the engine oil and oil filter every 5,000 to 7,500 miles to keep the engine running smoothly. 2. **Brake System Check**: Inspect brake pads and discs regularly, approximately every 10,000 miles, and replace them as needed to ensure safety. 3. **Tire Maintenance**: Check tire pressure monthly and rotate tires every 6,000 to 8,000 miles to ensure even wear and prolong tire life. 4. **Air Filter Replacement**: Replace the air filter every 15,000 to 30,000 miles to maintain optimal engine performance. 5. **Coolant Level**: Check and top off the coolant level regularly to prevent the engine from overheating. 6. **Battery Check**: Ensure the battery terminals are clean and the battery is functioning properly, especially before winter. 7. **Transmission Fluid**: Inspect and, if necessary, replace the transmission fluid every 30,000 to 60,000 miles to ensure smooth gear shifts. 8. **Spark Plugs**: Replace spark plugs every 30,000 miles to maintain fuel efficiency and engine performance. 9. **Suspension and Steering**: Regularly inspect the suspension and steering components to ensure a comfortable and safe ride. By adhering to this maintenance schedule, you can help ensure your 2007 Opel Astra continues to perform reliably.
If you're 27, with your family contributing 200,000 yuan, and you have a monthly salary of over 8,000 yuan, you can consider adding some money to buy a decent car. Depending on your preferences and needs, you might look at brands like Haval or BYD for reliable options. Keep in mind the fuel economy and horsepower that suit your driving habits.
If you're looking for an SUV around 130,000 RMB for daily family use, Chery Tiggo 8, Jetour X90, and Haval Big Dog are all decent options. Here's a brief overview to help you decide: 1. **Chery Tiggo 8**: Known for its spacious interior and good value for money. It's a solid choice if you prioritize comfort and practicality. 2. **Jetour X90**: Offers a roomy cabin with flexible seating arrangements, making it great for family trips. It's also equipped with a range of features for convenience. 3. **Haval Big Dog**: Stands out with its unique design and off-road capabilities. If you enjoy a rugged look and some adventure, this might be the one for you. Consider what features are most important for your daily needs, like interior space, tech features, or off-road capabilities, to make the best choice.
I just graduated and am starting out. My job is relatively stable, and I have a car at home to use. I don't have the pressure of renting since I live with my family. However, I've been thinking about buying my own car recently, with a budget of under 50,000. Do you think it's necessary to buy a car? I'm so conflicted. Commuting to work is quite convenient. I'm open to suggestions 🤗
When choosing between the Tahoe and the Q7, both are good options if you're looking for a larger SUV with 7 seats and have a budget around 70k. If you're also waiting for the Enclave for a comparison, it might be worth considering its features as well. Each of these models has its own strengths, so it depends on your specific needs like performance, luxury, or space.
Hello Polestar 2 owners! My family is considering getting an electric car for my wife, with a budget of around 100,000. We're worried about buying a new electric car and then regretting it later, so we're thinking about getting a used Polestar 2, either the 2020 launch edition or the 2021 model. I want to ask if this car is reliable as a second-hand option and if the range is dependable. Is it still a good choice to buy?
If you're looking to buy a used car with a budget of 40,000 RMB and you've got your eye on models like Lavida, Sylphy, Sagitar, and Jetta, here's a brief rundown: 1. **Lavida (朗逸)**: Known for its reliability and decent fuel economy. Look for models from around 2012-2015 for a balance of price and condition. 2. **Sylphy (轩逸)**: Comfortable and spacious, good for city driving. Consider models from 2013-2016. 3. **Sagitar (速腾)**: Offers a solid driving experience. Models from 2012-2015 could be a good fit for your budget. 4. **Jetta (捷达)**: Durable and economical, a popular choice for many. Look for models from 2012 onwards for better features. For city commuting, all these options are suitable, but it ultimately depends on your personal preference regarding style, comfort, and brand loyalty. Make sure to check the car’s condition and service history before purchasing.
I've been driving a Touran for 7 years, and it's time for a change. I'm looking for recommendations based on my needs. Here's what I'm looking for: I commute 25km one way to work, and there's no fixed parking spot in my community. The city is crowded, which tests my driving skills, so the car can't be too big. I'd like a space for a nap at noon, so electric or plug-in hybrids are preferred. We are a family of three, and we often take the kid out on weekends, so the car's stability and smooth driving are important as my family gets car sick easily. I often take care of the kid alone, and since the kid is not very strong, an electric sliding door would be great. My kid likes camping in the car, so it needs to have ample space. Occasionally, I need to move things between houses, so flexible space is a plus. Since my wife doesn't drive, we can only have one car. Right now, it seems like the GAC E8 is the only option 🤣
