Why does it still prompt "no memory card" even though I put a card in the SD slot during emergency braking?
Why is the tire pressure warning light still on even though the display shows 220? It's been a week and it hasn't turned off.
Any Accent owners here? I've been driving mine for over ten years without any issues. It just gets better with time. Even though I've bought a new car, I still can't let go of my old friend!
Hey car enthusiasts, I'm having some brake issues with my 2010 Volvo S80L. The brakes work fine when moving forward, but there's a chance of brake failure during short-distance reversing. A few days ago, when I changed the brake fluid, it was noticeably slow to drain out before adding the new fluid. Could it be that the brake fluid line is clogged? The brake pads are still quite thick, so I can basically rule them out. Any advice from the experts? 😬😬😬
4Why is the dashboard still showing "add windshield washer fluid" even though I've filled it up and it's spraying normally? Any suggestions?
5Why does it still prompt "no memory card" even though I put a card in the SD slot during emergency braking?
6Braking Dipping. I'm considering getting a standard 911. After a test drive of the 4S, I noticed a braking dipping issue. Even if I slowly release the brakes at the last moment, there's still a forward lurch just before coming to a stop. My current Mercedes doesn't have this issue, and neither did the Panamera I test drove earlier. Is it a matter of selecting the wrong mode, or is the car designed this way?
7Has anyone actually mentioned the car?! Why haven't I seen any reviews? Even though I'm not buying, I'm still curious to learn about it.
8If I add a turbo to a 2.5 Forester, can the transmission handle it? Or should I go for a stage 2 tune? The brake pads definitely need to be replaced, but I'm worried the transmission might not handle it, even though Subaru's transmissions are quite strong.
9Will you still buy the Sienna even though the price has increased?
10Help, everyone! Has anyone experienced this? While driving, the dashboard suddenly shows "brake," and the car brakes automatically, even though there's nothing in front.
