When I turn on the car lights, there's a buzzing sound, like a fan cooling down. Has anyone experienced this? How should I fix it?
Is there anyone experiencing a clicking sound when turning the steering wheel fully or going down a step? Is this a common issue?
Is your air conditioning cool enough? Other cars can go down to 16 degrees, but I feel like the Swift only goes down to about 22 degrees. It's not very cool, but not too hot either. 🤦♂️
Do you hear a humming sound on levels 1-3 when you turn on the air conditioner/fan? How can this be fixed?
4Is there any car owner who has experienced a buzzing electric current sound when the ambient lights turn on at night?
5When I turn on the car lights, there's a buzzing sound, like a fan cooling down. Has anyone experienced this? How should I fix it?
6When I step on the clutch of my Mitsubishi ASX manual, why does it make a buzzing sound, like the sound of accelerating?
7Hi, what could be causing the steering wheel to make a buzzing sound when turning?
8Can the startup animation and sound of the MG One be turned off? It's so loud every time that I feel like shutting down. 😅
9Is there anyone else experiencing a buzzing noise when the air conditioner is on fan mode?
10When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
