فهد رحمن
2023-08-28 15:43
When I put it in drive, the engine stalls. I have a 2017 model 95 with over 70,000 kilometers now. Recently, I've encountered a problem where the engine stalls when I put it in drive while waiting at a red light. It's happened a few times already, but the 4S shop couldn't find the issue. Has any fellow car owner experienced this problem?
عمر بشر
عمر بشر2024-01-13 06:27
Same issue with the 2017 GWM Haval! There's also the problem of stalling at low speeds initially.
حارثي سلمان
حارثي سلمان2023-09-24 16:37
I have the same issue. How did you solve it? Urgent! Urgent! Urgent! Which part is broken? The 4S shop here can't find the reason either.
عبد العزيز مطلب
عبد العزيز مطلب2023-08-29 21:32
Clean the fuel system.
What could be the reason for the 2018 BMW X1 stalling automatically in Drive? Has anyone encountered this issue?
Has anyone encountered a situation where the 2017 Smart car doesn't respond when put in reverse gear, and the engine warning light is on?
The display shows low battery, the engine suddenly stalls, and the whole car is unresponsive. What could be the problem?
Will I encounter Odin if I drive this car on the overpass?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
I have a 2012 automatic, and it often shifts to neutral when reversing, but there's no issue with driving forward. Has anyone encountered this problem? What could be the issue?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
Has anyone replaced their car battery? I drive often, and last night the battery was dead and I couldn't start the car. Have you guys encountered this before?
Changan Changan CS95
Changan CS95AED 89,500 ~ 136,500Gasoline & Petrol
