Sometimes I feel like the gear is stuck, especially when starting the car. Have you guys experienced this situation?
Hey fellow car enthusiasts, has anyone experienced starting on a steep slope where the car just slips and then stalls? This situation is becoming more frequent, and it feels like the transmission is slipping.
Why does it sometimes feel like the brake and accelerator are hard when I start the car, and other times they're soft? It feels uncomfortable to drive when they're hard.
4My H7 sometimes shows an ESP fault when I start the car directly. Do any of you fellow car enthusiasts experience this situation?
5Sometimes I feel like the gear is stuck, especially when starting the car. Have you guys experienced this situation?
62017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
7Does your CX-5 make a cicada-like noise at low speeds, especially noticeable when coasting at 60? Have any of you experienced this?
8Hey fellow drivers, just wanted to ask if any of you experience a strong drag when you let off the gas at low speeds, especially around 20 mph? It feels like the regenerative braking in electric cars. Have you guys encountered this issue?
9Have you experienced a situation where your Asian Lion's battery drains overnight, making it unable to start?
10Steering feels stuck and doesn't return to center. How do you guys deal with this? I've heard it can be fixed by reapplying grease to the steering gear. How much does it roughly cost?
