عمر تامر
2023-10-24 13:41
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
علي قنصوح
علي قنصوح2023-11-04 22:30
I've had it since 2017, and it's never had any issues.
20
ابيض سعود
ابيض سعود2023-11-04 19:22
Insurance burned!
نايف خديجة
نايف خديجة2023-10-24 15:28
My car too.
Can I plug in a USB drive? Where is the port located?
How do you charge your phone? The cigarette lighter USB can't charge my iPhone, but it works with OPPO. Does anyone have any solutions?
USB upgrade for Venus shows "USB not found." The USB is already plugged in next to the cigarette lighter.
Hey fellow car owners, does the 07 Lexus IS 250 (low trim without screen) have a BLIS system? Also, is there a USB port, and where's the cigarette lighter located?
Does anyone know where to replace the cigarette lighter fuse with a key symbol under the center console of the 2016 Grand Cherokee mechanical gear model?
Where is the cigarette lighter fuse located in the center console of a 2010 Honda City?
I just got my G70. How did everyone install their dash cams? Did you run the wires through the A-pillar and then route them under the center console to connect to the cigarette lighter?
The 2020 model only has one USB port. If you plug in a USB drive to listen to music, you can't connect the car kit. The USB extension ports you bought aren't working, and the USB in the armrest cigarette lighter also doesn't support USB drive for music or connecting the car kit. Do you have any suggestions for using both the USB drive for music and the car kit simultaneously?
Hey car enthusiasts, does anyone know what’s up with the Jietu 2024 Glory Pro's infotainment system not connecting? I plug in the USB and nothing happens. I'm using the original data cable that works fine when I connect my phone to a computer. But when I plug it into the car's USB port to connect to the infotainment system, there's no response at all. I've downloaded both E-Link Driving Assistant and Driving Companion apps on my phone, but neither works. Any ideas?
Changan Changan CS95
Changan CS95AED 89,500 ~ 136,500Gasoline & Petrol
