نايف شخبوط
2020-12-28 00:40
Is anyone else having issues with the 2019 model 95's lane assist controller malfunctioning and the reverse camera not displaying a signal? How did you solve it? Any suggestions? 🙏
Comments( 12 )
خالد مساعد
خالد مساعد2023-11-15 11:56
If you turn off the engine for about ten minutes, it'll be fine. The issue won't occur if you disable the lane assist. I often experienced this too, but after I turned off the lane assist, it hasn't happened again.
حسين ابيض
حسين ابيض2023-11-11 07:32
Just leave it overnight. It’s probably an electronic system crash. [I need some peace][I need some peace]
حسين ابيض
حسين ابيض2023-11-09 10:05
How did you solve this issue? My MD suddenly has the same problem today, with the 360 panoramic view malfunction and lane-keeping assist system failure. Last time, I had the car system upgraded at the 4S shop. [I want to be alone][I want to be alone]
محمد طيب
محمد طيب2021-08-07 16:05
Go to the 4S shop for a check-up.
20
حسين خليل
حسين خليل2021-07-28 20:11
I solved it by replacing the TF card. You can try running it without the card to see if the issue persists.
20
عبدالرحمن إياس
عبدالرحمن إياس2021-01-01 10:13
My 95 has shown four or five error codes. The one about the fuel cap not being closed properly was true, but the rest were false. The main screen went black a few times, so I got a new one. Other than that, there haven't been any issues. The power is excellent!
20
حمدان سعود
حمدان سعود2020-12-31 22:21
It seems like new cars always have this issue [facepalm].
2
خالد طه
خالد طه2020-12-30 12:07
Try restarting it.
أحمد زياد
أحمد زياد2020-12-30 01:11
I'll tell you the exact reason. I had this issue with my new car too. There's a main unit under the passenger seat. Usually, the reason is the connector is a bit loose. Just tighten it, and it should be fine. If it still doesn't work, ask for a replacement of the main unit. It's right under the passenger seat, and it's easy to install and remove. 😂
2
عمر فواز
عمر فواز2020-12-29 21:55
Just drive directly to the Changan factory. I handled my 95's issue this way, and it's more efficient than the 4S dealership.
The reverse camera display is glitching. Has anyone experienced this and knows how to fix it? It's been checked and seems like it's not an issue with the camera itself. Urgent!
Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
Does the 2012 Sportage GLS have a reverse camera? Sometimes when I reverse, it shows "searching for signal," and other times the central screen doesn't change.
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
My Jietu X70 has run 30,000 km, and when I cold start it, the idle is unstable, and the car shakes. After about ten seconds, it gets back to normal. There's no error displayed. I left it at the 4S shop for a week, and they cleaned the throttle, carbon buildup, and fuel injectors, but it didn't help. The 4S guys said it might be the fuel, so I switched gas stations, but there's still no change. Has anyone else experienced this? How did you solve it? Please let me know. 🙏
When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
Changan Changan CS95
Changan CS95AED 89,500 ~ 136,500Gasoline & Petrol
