علي سا مرعي
2024-10-06 22:06
I've had my car for over a year, and the auto start-stop has never worked. I went to the dealership, and after a test drive, the service staff said it works, but I need to turn off the AC for it to function. I've turned it off, but it still hasn't activated. How do you guys use it?
عوادة سعود
عوادة سعود2024-10-07 06:35
No start-stop is much better. The start-stop system itself is just trash.
مرشد نايف
مرشد نايف2024-10-07 01:20
After installing a remote power cut-off device on the battery of my new car, an orange icon has been displaying continuously.
Hey guys, why does the AC sometimes turn on by itself after starting the car? I usually don't forget to turn it off.
What could be the issue if the auto start-stop feature on a 3.0 Grand Cherokee hasn't worked since I bought it less than a year ago?
How do I turn off the auto start-stop on the ILX? 😅
The transmission light on your car suddenly turned on for a few minutes and then went off. Sometimes it lights up while driving, but it hasn't come on in the past few days. What could be the reason?
Can the auto-folding mirrors when locking the car be turned off?
Can the ECO mode be turned off when driving a 2023 Toyota Allion Elite in D gear? Also, is it true that the headlights can only be on auto and cannot be turned off completely?
To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
Fellow car enthusiasts, have any of you experienced this situation where the transmission control system malfunctions, the power can't be turned off, the key fob lock button stops working, and then everything returns to normal after about half an hour to an hour? It's a three-month-old car, and this issue has occurred multiple times. I've been to after-sales service, but it hasn't been resolved.
Changan Changan CS95
Changan CS95AED 89,500 ~ 136,500Gasoline & Petrol
