I'm thinking about changing my spark plugs recently. What brands do you guys use?
Has anyone changed the spark plugs on a 2018 manual MG ZS? Which brand is better? Any recommendations?
Is the headlight of the 2019 Changan Alsvin automatic a combination of low and high beam, or are they separate? I'm thinking about changing the bulb recently!
I'm thinking about getting a used Jetta this year. Which model do you guys recommend? Thanks for the comments.
4I've driven nearly 40,000 kilometers and I'm thinking about changing the spark plugs. Which model should I choose between Bosch and NGK? I saw a Bosch double platinum spark plug online. Is it necessary for this car to use double platinum?
5Hello fellow Wrangler owners! How many kilometers should I go before changing the spark plugs on a 2.0T JL Wrangler? And which brand do you recommend? Thanks for the suggestions!
6The original spark plug failed after just over 10,000 kilometers. How about you guys?
7Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
8I'm thinking about changing my spark plugs recently. What brands do you guys use?
9Hey guys, at 90,000 km, do I need to change the spark plugs? If yes, should I go for Champion or Mopar?
10My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
