Hey car enthusiasts, my 2017 4WD Smart Drive version stalls when I shift to Neutral (N) or Park (P). Has anyone else experienced this issue?
When driving a 2016 Middle East version of the Fortuner in low-speed 4WD (around 30 mph), I switched directly to neutral and then to high 4WD. After that, the car wouldn't move, and it rolls in P gear. What's the issue? Is it the transfer case or the transmission that's broken? Has anyone experienced the same situation? Thanks.
Have you ever encountered an issue where the car shifts from P to N?
4Guys, today I tried flooring it in Sport+ mode and heard a rustling sound that lasted about 5 seconds before disappearing. No error codes on the dashboard, and the car drives fine. However, when I parked and shifted to P, there was a continuous electrical noise. The noise disappeared after switching to neutral and back to P. Could there be an issue with the transmission? How should I check it?
5Guys, I'm really freaking out. Just now, while driving smoothly, the D gear light (the one on the gear shift) started flashing, and the dashboard showed "Please shift to D gear first before selecting the appropriate gear." I was in a panic and didn't know whether to press the brake and shift to P gear or shift to P gear and then to D gear, and then it prompted "Speed too high to shift into D gear (or maybe P gear, I forgot)." It was terrifying, the car felt like it was in neutral and there was no power when I pressed the accelerator. I managed to park on the side using inertia, shifted back to P gear, and then to D gear, and it resumed normal driving. I want to ask you guys, what's going on here exactly? Is there a specific part that's malfunctioning?
6Before driving, I can only shift gears by pressing the shift lock button, and once I shift back to the P gear, I have to press the lock button again to shift! The brake lights are working fine! I recently replaced the handbrake cable and gear cable. Has anyone else experienced this situation?
7Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
8Today, my car suddenly won't start and won't shift gears. The screen displays a message saying "Please shift to P or N." Have any of you encountered this situation before? What's the solution? 🤦♂️🤦♂️🤦♂️
9Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
10Hi everyone, I'm a newbie here and I have a question. When you park your Panamera on a slope and put it in P, does it roll a bit and make a loud clunk sound when you release the brake? And when you shift from P to N, is there also a clunk sound? My new car makes a really loud noise. It's scary, I almost thought I got hit.
