سعود أرسلان
2024-11-30 01:27
Why is my USB not responding when I plug it into my 2017 Changan CS75?
علي فخر دين
علي فخر دين2024-11-30 19:43
If it works when plugged into the computer, check the format of the USB drive. It should be formatted to FAT32 or exFAT.
عبدالرحمن ظافر
عبدالرحمن ظافر2024-11-30 12:00
You can plug it into the computer first to check if the USB drive is working properly.
Can I plug in a USB drive? Where is the port located?
Why is my car key suddenly not responding and unable to lock the doors?
Why does my car jerk noticeably and respond slowly when I start and accelerate? 😢 It's really uncomfortable to drive. Fellow car owners, how can I solve this issue?
USB upgrade for Venus shows "USB not found." The USB is already plugged in next to the cigarette lighter.
My 2019 Model 95, the USB port next to the cigarette lighter on the center console isn't working. It doesn't charge my phone, and when I plug in a USB drive, there's no response. What's going on?
Why is the USB port in my Koleos not powered?
Why can't I play music from a USB on my Chery Jetour X70 Plus?
What should I do if the USB flash drive is not responding when plugged in?
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
Why can't my newly purchased USB drive be read and why does it show as not connected?
Changan Changan CS75
Changan CS75TBDPetrol
