سعود حمدان
سعود حمدان
Nov 26
When the car is idling at a red light, and there are popping sounds similar to air blasts or backfires, what's happening?
Comments( 6 )
عبدالرحمن بارزاني
عبدالرحمن بارزاني2024-12-03 11:07
Thermal expansion and contraction of the exhaust pipe.
فهد أنيس
فهد أنيس2024-11-29 17:09
I heard a loud bang from the back today. Not sure if it's the exhaust making noise. It might be due to the weather; never experienced this before, but it's gotten colder now.
حسن كلثوم
حسن كلثوم2024-11-27 16:35
There are a few popping sounds coming from the left rear side, and I still haven't figured out the cause.
نايف تامر
نايف تامر2024-11-26 23:12
Did you fill up at the small gas station?
عبدالرحمن ظافر
عبدالرحمن ظافر2024-11-26 21:36
Is there knocking?
سا مرعي محمد
سا مرعي محمد2024-11-26 20:57
Try a different gas station when refueling.
When turning on the air conditioning in my 2006 Previa ACR50, I occasionally hear this sound. Can any experts help explain what's happening? Has anyone experienced a similar issue, and what could be the cause? It's a 2.4.
My 10-year-old car makes a strange noise when I accelerate hard or when going uphill. The sound is like "pop, pop, pop." Does anyone know what the issue might be?
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
When you warm up your car or are idling at a red light, can you hear a "tatata" sound inside the car? Sometimes it's there, sometimes it's not. It's not the engine sound. Even if you press the accelerator a bit, the "tatata" sound frequency stays the same. Not sure what's causing it.
Gv80 shifts to neutral at a red light, makes a thump sound when starting.
I've noticed a "pop" sound coming from the front of the car when it's cold. Once I start driving, everything seems normal. The dealership said they'd need to keep the car there to check it. Has anyone experienced a similar issue? What could be wrong? It's happened multiple times already.
When the air conditioning is on and blowing cold, the car shakes a lot, especially when stopped at a red light. It's uncomfortable. Do any of you have this issue with your car?
When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
When driving the Kamiq, if a red "P" appears on the dashboard and there's a beeping sound similar to the seatbelt alert, what could be the issue? Can anyone advise? Thanks!!
Changan CS75
Changan CS75SAR 89,250Gasoline
