علي مبارك
علي مبارك
Nov 26
Hello fellow car enthusiasts, has anyone experienced slow air leaks with the 2023 Enjoy Edition CS75's tubeless tires? The service staff at the 4S shop said they couldn't find where the leak is and suggested I get it checked and repaired outside. How did the 4S shop handle this issue in your area?
Comments( 10 )
عبدالرحمن بارزاني
عبدالرحمن بارزاني2024-12-03 10:57
Buy a manual air pump and inflate every 10 days or so. Too lazy to go to the 4S shop. Before buying a car, you're the boss; after buying a car, you're the servant.
2
أحمد عرفات
أحمد عرفات2024-12-01 05:02
The left rear of my car [I want some peace and quiet]
سلمان دل
سلمان دل2024-11-30 23:26
It seems like all the tires are losing air. I've had the car for a year and a half, and I remember I've refilled the air 5 times.
حسن رشيد
حسن رشيد2024-11-30 18:59
Most of the time, it's the valve stem that's leaking. I already replaced it a month ago and now there's no leak at all.
حسين مصطفى
حسين مصطفى2024-11-30 18:16
My car's four tires had leaking valves. The dealership where I bought the car said it was normal. Later, I went to another 4S shop to replace them. During maintenance at Tuhu, I asked the technician to check, and they found that the valves were leaking.
عبدالله سلطان
عبدالله سلطان2024-11-29 21:17
My new car has slow leaks in two tires. The leak is next to the valve stem. I replaced the tire pressure monitoring sensor, but it didn't help. Later, I changed the rims.
2
عمر زبير
عمر زبير2024-11-27 13:01
It's the same for me. My left front tire loses 0.1 every ten days. I keep an electric air pump in the trunk, so I just inflate it myself when it drops.
نايف تامر
نايف تامر2024-11-26 23:18
My right rear wheel has the same issue. I don't really mind; I just keep an air pump in the trunk and inflate it once every ten days or so.
سعود فاطمة
سعود فاطمة2024-11-26 17:32
My new car had a slow air leak right after I bought it. Later, I checked it myself and found the leak was at the valve stem.
عمر بكر
عمر بكر2024-11-26 15:53
It might be a valve leak.
Now that the car company has gone bankrupt, what happens to the maintenance services promised by the 4S shop? The contract was signed with the 4S shop...
In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
Why is maintenance at 4S shops so expensive, folks? Can I get maintenance done outside of 4S shops?
I just received the news that the local 4S shop has closed. I want to ask, for car owners without a local 4S shop, how do you handle regular maintenance? Do you have to go to another city for the 15 maintenance services over the 5 years for a new car?
Can I get this car serviced at a Hyundai 4S shop?
Will there be a color difference if I get the grapefruit gray touch-up paint done outside? Do 4S shops have the original paint?
Is it reasonable for the 4S shop to charge 500 RMB to disassemble and dry the area under the seats due to blocked sunroof drainage while still under warranty?
I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
Does your car have a rattling noise in the timing belt area? I went to the 4S shop and they said it's nothing. 🤥🤥🤥
Has anyone experienced a metallic knocking sound when starting the 2024 Cayenne? I've been to the 4S shop several times but they couldn't find the source.
Changan CS75
Changan CS75SAR 89,250Gasoline
