سعود صالح
2024-11-24 22:46
Do you experience any strange noises from the right window when driving your '24 model 75 on uneven roads?
محمد خير الدين
محمد خير الدين2024-11-25 07:19
Yes! It's like the sound of a loose screw rolling around!
Why is there always a strange noise coming from the chassis?
Does your F150 have any rattling noise? Mine might be due to driving on dirt roads a lot, there's a bit of noise, like the sound of leather rubbing.
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
When the Sportage makes a thumping noise over uneven road surfaces, what's the issue?
Is there anyone who has experienced rattling noises from the center console screen and the driver's side door when driving on uneven roads in the 2019 Taurus? It's driving me crazy!
Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
Changan Changan CS75
Changan CS75TBDPetrol
