سعود بشر
سعود بشر
Nov 20
Who has the maintenance manual for the 2018 manual transmission model? Specifically looking for the oil type, brake fluid type, etc. Thanks!
سعود مساعد
سعود مساعد2024-11-21 10:25
I've changed the coolant, brake fluid, engine oil, gear oil, and all the filters myself. The car is less than 6 years old with over 70,000 kilometers on it. No major issues, but there's a lot of noise and a strong smell in the summer.
20
What type of transmission fluid should be used for a Mazda CX-7 2.5?
For the BYD Song PULS fuel version, if you're not going to the 4S shop for maintenance, what type of engine oil and transmission fluid should be used?
What's the engine oil grade listed in the maintenance manual for March? Thanks!
What type of transmission oil should I use for my Mazda 5? Planning to change it, thanks.
What type of oil should be used for a Nissan Kicks during maintenance?
Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
What type of transmission oil is used in the Changan Suzuki Alto? What is the specification?
What type of engine oil do people generally use for a newly purchased second-hand 2008 2.0? How often should the transmission oil be changed? Thanks!
What type of engine oil should everyone use for maintenance?
My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
Changan CS35
Changan CS35AED 63,000Gasoline
