Hello everyone, has anyone experienced this with the 2019 model 35p automatic? Currently, I've driven 60,000 kilometers, and occasionally when I brake at a red light, the idle speed fluctuates. How did you deal with it? I've cleaned the throttle and replaced the spark plugs, but I still don't know why it's happening.
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
After a major maintenance on the 2006 Accent 1.4 manual, the spark plugs, carbon canister solenoid, and throttle have been replaced, and the fuel injectors have been cleaned. With the fuel price at 7.91, it's costing 0.9 per kilometer. Is this normal? The oxygen sensor is fine!
4What could be the reason for the idling vibration in a Nissan Sunny manual transmission? I've replaced the spark plugs, but it hasn't solved the issue.
5Dear fellow car enthusiasts, I've been experiencing an issue with my 2008 Yaris where it occasionally stalls while idling at a red light. After restarting, it might stall again at the next red light. This happens two or three times, but then it runs fine afterwards. There are no error codes on the dashboard, and when I took it to the repair shop, the diagnostics showed everything was normal. Does anyone know what the problem might be?
6Hello everyone, has anyone experienced this with the 2019 model 35p automatic? Currently, I've driven 60,000 kilometers, and occasionally when I brake at a red light, the idle speed fluctuates. How did you deal with it? I've cleaned the throttle and replaced the spark plugs, but I still don't know why it's happening.
7I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
8Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
9Has anyone experienced gear shift jerking after just replacing the spark plugs and cleaning the throttle? It was fine for two or three days, but then the jerking returned.
10In the morning, when starting the vehicle and driving at low speeds, it occasionally stalls. I've already cleaned the throttle and injectors, but it still stalls sometimes. If the speed picks up, it doesn't stall. What could be the reason? 🤦♂️
