Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
Do I need to replace the timing chain at 100,000 kilometers?
How many kilometers should a timing chain be replaced?
Foton Cummins engine, 2.8T engine having diesel entering inside, causing the oil dipstick to rise by two to three centimeters every few hundred kilometers. The high-pressure fuel pump has been replaced, and the injectors have been calibrated without any issues.
4Does the timing chain of a 2013 MG3 need to be replaced? It's only been 100,000 kilometers. Has anyone changed it before?
5Will the timing chain of the 2017 automatic luxury version engine stretch?
6The engine in the Iveco Ousheng 2.0 uses a timing chain.
7How many kilometers does the timing chain of a 380 need to be replaced?
8Has the T-Cross been recalled for a fuel pump replacement at the 4S shop? Have you noticed higher fuel consumption after the fuel pump was replaced?
9Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
10Does anyone know if the oil pump drive for the 2018 35P 1.6L is a belt or a chain? Thanks!
