عبدالرحمن صلاح الدين
Nov 22
Every time I lightly press the accelerator, the engine revs up to 3000 RPM, but the car speed is only around 20 mph. What could be the problem? My car is a 2023 model 35 Plus.
Does anyone know why the Volvo V40 T3 version feels weak during acceleration around 60 mph, and why the steering wheel shakes when lightly pressing the accelerator?
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵💫 Do any other T-Cross owners experience this situation?
4The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
5Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
6Is it normal for my manual comfort version car to have the engine rev up to 3000 RPM and make a lot of noise when driving over 100 km/h on the highway?
7For a 10-year-old black Jetta, when lightly pressing the brake, the ABS engages, and at around 10 mph, the ABS starts working. What have others replaced to solve this issue? [facepalm]
8When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
9For the 2023 Changan CS35 Plus, when using the CTS-03.08.06.0W-20 Changan-specific full synthetic oil, how many kilometers should the oil be changed during maintenance?
10Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
