حسن لطيف
2024-10-10 17:24
Dear friends, can the 2023 CS35P's auto-hold function be set to turn on automatically? Or do you have to press it manually each time?
عمر عل
عمر عل2024-10-13 11:57
Once you start it up, you almost don't need to think about it. On the routes you frequently travel, you're already familiar with the traffic lights, and you drive based on your own feel.
فهد رامي
فهد رامي2024-10-11 04:53
It seems like I can't "[I want to be alone]."
أحمد جعفر
أحمد جعفر2024-10-10 20:33
It can be set to turn off.
2
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
Does this car not have the Auto Hold function? I couldn't find it.
How do I disable the automatic start-stop function on the 2016 Peugeot 508, guys? Every time I start the car, I have to manually turn it off.
Can the 2015 2.0 Ultimate 508 be set to have the "adaptive rearview mirror during reverse" function? I've tried following the manual a couple of times without success. Does this version not have this feature?
After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
Can the ECO mode be turned off when driving a 2023 Toyota Allion Elite in D gear? Also, is it true that the headlights can only be on auto and cannot be turned off completely?
Hi fellow car enthusiasts! Does the 2023 model of the Asian Lion Elite Edition have an auto door lock feature when driving? How do you set it up?
I have an 11-year-old Sportage that's done 140,000 kilometers and I haven't changed the timing belt yet. Dear friends, at how many kilometers did you change yours?
Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
Changan Changan CS35
Changan CS35AED 63,000Petrol
