This morning I noticed that there are only 7 gears in manual mode, what's going on?
I'm having trouble starting my E3 in the morning. What's going on?
Why can the T60 Petrol 2.0T Automatic 4WD only upshift but not downshift in manual mode?
When using the paddle shift manual mode in the HS with the S gear, do I need to press the brake pedal to change gears? In the past, when I drove a fully manual transmission, there was a clutch pedal. [Facepalm][Facepalm][Facepalm][Facepalm]
410-year Mazda 5 manual, when I start the car in the morning, the engine is very loud. But after driving, the noise reduces significantly. What's the reason for this?
5I bought a second-hand 2019 Kia Pegas, and the fuel consumption at idle jumped from 7 to 10. What's going on?
6Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
7This morning I noticed that there are only 7 gears in manual mode, what's going on?
8Hi everyone, in my second-hand 2014 V60, the manual shift mode can only upshift but not downshift. Is there a problem with the transmission? Any advice?
9[Shocked] What's up with this car? Starting in S mode, I floored the pedal, the RPM hit 4000 and it was still in 2nd gear without shifting up automatically. It only shifted to 3rd gear after releasing the throttle for 3 seconds.
10Guys, I have a 2017 1.6 Zhixing. Last month, while driving, it showed a message to shift to P gear for repair, but it disappeared after a while. This morning, it reported a transmission fault, but after starting the car, it was gone again. What's going on?
