أحمد عبد لطيف
2024-02-28 22:50
Is it normal to hear a squeaking sound from the engine while idling when sitting in the cabin?
Is it noisy for people sitting in the car while driving on the highway? Specifically, when the boss is driving at high speed, is the exhaust sound loud inside the car during normal driving? Looking forward to your insights! 😊
When your car is idling or waiting at a red light, can you hear a "ta-ta-ta" sound? I notice it every night after work when it's quiet, and it's really annoying. It's the same "ta-ta-ta" sound even if I rev the engine in neutral. The frequency of the sound is the same at different RPMs as when it's idling. Not sure what the issue is.
When driving a 206 with a 1.6 automatic transmission, whether on the highway or at low speeds, the engine noise becomes very loud once the RPM exceeds 2800. There's a buzzing sound inside the cabin that is even louder than the wind noise—it's really loud! When the car is idling after warming up, there's a noticeable vibration if you hold the steering wheel or sit in the seat. What could be causing this? Looking for guidance from experts!
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
What could be the issue if there's a clicking sound from the steering wheel when idling?
Do you also hear noise from the engine while inside the car?
Is it normal to feel slight vibrations when sitting inside a Patrol 4.0 at idle?
Is it normal to frequently hear a low-frequency buzzing sound while driving the Taycan?
Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
