I am sincerely asking for advice from everyone: When buying Subaru oil filters, air filters, and cabin air filters online, which specifications are the same between Subaru Impreza, Forester, and Outback?
The air conditioning filter in the S40 is typically located behind the glove box. To replace it, you generally need to follow these steps: 1. Open the glove box and empty its contents. 2. Gently unhook the glove box to allow it to drop down further, giving you access to the filter compartment. 3. Locate the air conditioning filter cover, which is often held in place by clips or screws. 4. Remove the cover to access the filter. 5. Take out the old filter and insert the new one, ensuring it is positioned correctly according to the airflow direction indicated on the filter. 6. Reattach the cover, secure the glove box back in place, and close it. Always refer to the vehicle's manual for specific instructions, as the process can vary slightly depending on the model year.
Where did you guys buy your air filter and cabin filter? Can you share a link?
4I am sincerely asking for advice from everyone: When buying Subaru oil filters, air filters, and cabin air filters online, which specifications are the same between Subaru Impreza, Forester, and Outback?
5I have a 2012 Subaru Outback with an EJ25 engine, almost 200,000 kilometers. It has noticeable shaking at idle and stalls during sudden braking, especially when the engine is cold. I cleaned the throttle body carbon build-up recently, which improved it a bit but didn’t completely solve the problem. The engine is quite loud during hard acceleration, and I’m not sure if it’s the engine or the transmission. Also, recently it shakes at speeds over 100 km/h. Anyone experiencing the same issues?
6Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
7I just bought a Subaru Forester 2.5 naturally aspirated. Is a fuel consumption of 13 with the air conditioning on normal? I would like to ask for advice from experienced users.
82021 Outlander Vehicle Odor Issue. Background: Recently, the car was parked in an underground garage for a month, and the garage was somewhat damp. Situation: An unpleasant odor, like a musty and rotten smell, has started to accumulate inside the car. Self-assessment: I've checked the interior but couldn't find the source of the smell. I also replaced the air conditioning filter, and the air blowing out doesn't have any odor. However, as soon as the car is parked for half a day and I get back in, there is a strong smell in the cabin. The car has never been submerged in water or flooded before. Question: Has anyone experienced a similar issue and can provide some guidance on how to deal with this?
9Hey guys, the 4S shop is charging 138 for the air filter and 88 for the cabin filter. I didn't buy them. What brand should I go for? Or should I stick with the 4S shop's original filters? I'm hesitant to buy online, worried about fake products.
10Which brand offers better cost-performance for air filters and cabin filters?
