Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
When lightly pressing the brakes on the Vellfire, there's a slight "click" sound. Has anyone else experienced this?
I have a 2018 2.0 4WD Jeep Renegade. When I start the car, while the gear is in the P position and I press the brake, I hear a clicking sound from the gear area. Has anyone else experienced the same issue?
I have a 2015 manual car, and there is a slight clicking sound when refueling. How can this be addressed?
4Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
5Does this car not have the Auto Hold function? I couldn't find it.
6I went for a test drive at the dealership. The steering wheel felt heavy, maybe I'm not used to it. But why does it feel uncomfortable when lightly pressing the accelerator at low speeds? It's like something's holding you back from going fast, yet tempting you to press the pedal harder.
7Sometimes when I wait for the RPM to drop after starting the car, the engine noise is really loud. The sound gets louder or softer depending on how hard I press the accelerator, and the throttle doesn't feel as powerful as it usually does, requiring me to press it deeper. However, most of the time, this doesn't happen. After the RPM drops, the noise is normal.
8When starting on a slope with a temporary license plate and using auto hold at a gate, the car tends to roll back when pressing the accelerator after the gate opens. Have any experienced car owners encountered this issue? How do you solve it? Should I use the electronic handbrake? PS. I didn't have this problem with my previous Volkswagen Golf. When stopped on a slope, I just kept the brake pressed and it moved forward when I pressed the accelerator, without rolling back.
9Dear friends, can the 2023 CS35P's auto-hold function be set to turn on automatically? Or do you have to press it manually each time?
10Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
