علي باسل
2024-12-06 09:31
When adaptive cruise control is activated, should your hands not leave the steering wheel?
عبد العزيز يوسف
عبد العزيز يوسف2024-12-06 13:06
One downside of this L2 system is that when the car in front stops, we stop too. But when the car in front moves, our car doesn't automatically start moving. Not sure how it is with other brands.
عبدالله نبراس
عبدالله نبراس2024-12-06 10:20
Try not to rely too much on tech tricks, and use them sparingly.
نايف هاماوي
نايف هاماوي2024-12-06 09:46
L2 is not fully autonomous driving; human control is definitely required.
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
Can the premium version, which only has cruise control, be upgraded to adaptive cruise control?
Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
Can the 2019 EcoBoost 245 Yuexiang Edition be upgraded with lane departure warning and adaptive cruise control?
Can we retrofit adaptive cruise control (ACC) on our Territory?
Does the 2023 Macan 2.0T come with standard cruise control or adaptive cruise control? Can someone explain this?
How well does the car's adaptive cruise control work in traffic jams? Is it practical? I'm only interested in its performance in traffic jam situations.
The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
Toyota Toyota Corolla Cross
Toyota Corolla CrossAED 89,900 ~ 109,900Hybrid
