نايف عبد لطيف
نايف عبد لطيف
Nov 29
Today, when I connected my car's system using a data cable, I discovered an issue! I'm curious if any fellow car enthusiasts have experienced the same problem! When the car is powered on but not started, there's a "click" sound every 20 to 30 seconds, like a screw dropping into a bowl or a light tap. It's particularly noticeable in a quiet environment. Is this normal?
خالد قابوس
خالد قابوس2024-12-03 21:04
When you open the hood and listen closely, it sounds like there's a cricket living inside the ABS pump behind the engine, chirping every twenty seconds. 🤦‍♂️
فهد أنس
فهد أنس2024-12-02 23:39
Solenoid
نايف عبد لطيف
نايف عبد لطيف2024-11-30 08:48
Anyone else experiencing this? For the Pioneer Edition, when you insert the key and turn on the power without starting the car, and then turn on the car stereo, listen closely...
The original oil is 2w/20, and now it's over 100,000 kilometers. Do I need to switch to 0w/30? Does a car with such mileage count as an old car with increased wear and tear?
My original 2019 car dashcam is offline because the original data cable is lost. The dealership said they don't have the cable. What should I do to activate it now?
I accidentally discovered that when switching gears on the Grand Cherokee, there's a noticeable "click" sound from underneath the chassis. However, the driving is smooth with no abnormalities. Have any fellow car enthusiasts experienced the same situation?
Hey car enthusiasts, does anyone know what’s up with the Jietu 2024 Glory Pro's infotainment system not connecting? I plug in the USB and nothing happens. I'm using the original data cable that works fine when I connect my phone to a computer. But when I plug it into the car's USB port to connect to the infotainment system, there's no response at all. I've downloaded both E-Link Driving Assistant and Driving Companion apps on my phone, but neither works. Any ideas?
Toyota Corolla Cross
Toyota Corolla CrossOMR 9,750 ~ 11,517Hybrid
