Is there a recall for the Sharp Fuel model?
Fuel consumption for a 2008 1.6 model.
I heard that this car was previously recalled to the 4S shop for replacing the airbag inflator, or perhaps the airbag itself. Is that the case?
Did anyone else receive a recall notice recently for the 280 regarding the fuel rail bolts issue? The recall is starting at the end of February.
4What is the fuel tank capacity of the 2020 model?
5Is the 2019 model V97 using 92 or 95 fuel?
6Is it necessary for the 2021 Nissan Teana to be recalled by the manufacturer for EGR valve replacement?
7Will the Prado launch a purely fuel-powered 2.4T model? Will the fuel version be cheaper than the hybrid?
8What's the situation with the 2019 X-Trail EGR valve recall, and should it be replaced?
9Has the T-Cross been recalled for a fuel pump replacement at the 4S shop? Have you noticed higher fuel consumption after the fuel pump was replaced?
10Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
