Is it normal for the paint on both rear fenders of the Haval Jolion to be different from the body, slightly yellowish?
Has anyone noticed that the rear wheels' heights on both sides are different with the 3.6 air suspension?
The Vellfire has been driven over 40,000 kilometers, and there's a lot of noise coming from the rear tires. Upon inspection, the inner tires are worn, and both tires are the same. What could be causing this?
Does the front-low, rear-high stance of a Land Cruiser pose any safety risks? How does it differ from a standard suspension setup?
4I just got a 206, and I've noticed that the body is lowered. Is it coilovers or lowering springs? I noticed the rear chassis is different from regular cars. Any advice?
5I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
6If you're looking to get the 2022 Haval H7, you might want to check out local dealerships for inventory cars. You can also explore online marketplaces and forums where car enthusiasts gather, as they often have listings for both new and used cars. For a used car with good condition, certified pre-owned programs from dealerships could be a reliable option.
7When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
8Is it normal for the Haval Jolion Comfort edition to lurch slightly when you park on a slope, shift to P, engage the electronic handbrake, and then release the foot brake?
9The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
10What is the code on the nameplate for the 2025 model? Is there a difference from the 2024 model? What would be considered a normal production time for the 2025 models currently being sold?
