Are halogen lights bright enough? Has anyone switched to LED bulbs?
Hi guys, does the 2017 GS7 1.8T have halogen bulbs or xenon bulbs for the low beam headlights?
Hi everyone, I'm looking to upgrade the halogen headlights on my 2014 Yizhi to LED ones because they're not bright enough. Any good recommendations? Thanks!
Does anyone feel that the headlights of the Yaris X are not bright enough? Has anyone modified the headlights, and are there any compatible headlights available now?
4Hey folks, are your car lights bright enough? I'm thinking about changing mine because they don't seem bright, but it looks like I have to remove the entire headlight to do it. Has anyone done this before? Any advice?
5Hey folks, when you switch to LED bulbs, do you also change the lens?
6Hey guys, has anyone successfully replaced the halogen bulbs with LEDs on a 301? Is it something I can do myself, not too difficult? Could you share a link? Thanks!
7Why is the new bulb on the 2019 X90 not as bright as the original after replacing the original bulb?
8I bought a used 2018 Peugeot 3008 and feel like the halogen lights aren't bright enough. I replaced them with LED bulbs, but the light is still scattered and not good. Could you suggest what bulbs I should use? Also, does the original car come with projector lenses?
9Could you recommend a car light? I feel like my current ones aren't bright enough.
10If you're planning to replace the LED lights on a 2013 Kia Sportage yourself, you'll need to know the specific model of the LED lights required. It’s best to consult the vehicle's manual or check the existing LED bulbs for their specifications.
