حسين نبيل
2024-11-06 20:17
I have a 2020 Mini Cooper F56. Last year, I started the car and noticed the RPM was steady between 2000-3000. The same thing happened today. When I stopped at a red light and turned off the start-stop system, the RPM was at 1000. But as soon as I pressed the accelerator, it went back to 2000 RPM and wouldn't go down. Normally, the RPM is just above 1000. What could be the issue?
Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
Has anyone experienced their car's tachometer suddenly jumping above 3000 RPM and then dropping back down while driving?
What type of battery is suitable for a 2019 Mini Cooper S 2.0T Artist Five-Door Edition? Do I have to replace it at the dealership?
2017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
The "circle A" symbol for the start-stop system on the 2021 GV80's dashboard is flashing continuously, and the RPM won't go above 2500. Pressing the start-stop switch doesn't make any difference. Can anyone help explain what's going on?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
Hello fellow car enthusiasts! I'm having an issue with my car and would like to seek your advice. The check engine light is on, and it's hard to start the car (it takes a while to start). Once it starts, the RPM is normal, but as soon as I shift gears, the RPM immediately jumps to over 1000, almost 2000. When I shift back to Park, the RPM slowly returns to normal. I've already replaced the throttle, and it worked fine for two days, but now the same problem is back. Has anyone else encountered this? What could be the issue?
Hey fellow car enthusiasts, do you also notice that when you start the car in P gear, the engine revs quite loudly, usually above 1000 RPM? But once you shift to D gear, it drops below 1000 RPM and the sound gets much quieter. Is that the case for you too?
