Can the low-end steering wheel of a Mini R56 be upgraded to a high-end steering wheel to achieve additional functions?
Does a wooden steering wheel have a heating function?
Can the steering wheel be adjusted?
At the end of November, I replaced the control arm, steering rod, and axle assembly. Now the steering feels very light. When going over bumps, the steering wheel moves erratically. If I accelerate a bit aggressively, the steering veers off. Can someone help me out? [crying]
4Can the stock 21-inch wheels of the Hongqi EHs9 be upgraded to 22-inch wheels?
5You can consider upgrading the wheels on your Subaru Liberty Wagon to a larger size to prevent scraping against the chassis and front end. Typically, people upgrade to 17 or 18-inch wheels for better clearance and aesthetics. However, make sure to check for compatibility with your vehicle's suspension and wheel well space, and consult with a professional to ensure safety and performance.
6What functions does the lever on the lower left side of the T99s Sport Edition steering wheel have? 🙏
7What do you think about this car with the low-end model at 219,800 RMB, the mid-range model at 239,900 RMB, and the high-end model at 269,900 RMB?
8Why is it that the high-end X and S are about the same, but the low-end X is much more expensive than the S? I really like the X. [crying]
9Is there a low-end model that can be upgraded with a large screen?
10How can I adjust the steering wheel weight on the Tucson L? The steering wheel feels too light and a bit wobbly when driving at high speeds.
