فهد نور الدين
2024-06-16 12:14
2018 model, two-door F56, there is a continuous and noticeable thumping sound from the right rear of the vehicle at idle. I've checked it myself, and when I unscrew the fuel cap, the sound stops immediately. Once I put it back on, it starts again after a while. If I cover the fuel cap with my hand, the sound stops right away, but once I remove my hand, it starts again. I suspect it has something to do with a component related to the fuel tank, perhaps the charcoal canister or the fuel tank vent? Anyone knowledgeable can help? I feel like I'm close to solving the problem, can someone assist?
فهد نور الدين
فهد نور الدين2024-06-16 12:18
Just to clarify, if you cover it with your hand, it makes a sound, but when you remove your hand, it stops, just like covering it with a lid.
Recently, my fuel tank cap often won't open. Sometimes hitting it with my fist works. Any guidance, please? Thanks!
How to deal with a fuel tank cap pull ring that won't open, and I can't find the emergency pull ring in the trunk.
How to open the fuel tank cap on a 2019 Ford Territory?
Where is the fuel tank switch on the 2013 City? Do you just press the fuel tank cap to open it?
How many liters is the fuel tank exactly? I refueled 42 liters after the light came on, and it automatically stopped. Isn't it supposed to be a 50-liter tank?
I just bought a used 2016 Santana, and I'm trying to figure out how to lock the fuel tank cap. I realized it can be opened no matter what I do.
For the 2015 Peugeot 3008, the fuel gauge was previously inaccurate, and the fuel tank got dented. After replacing the charcoal canister and the gray filter, the fuel gauge is still not accurate, sometimes showing more and sometimes less.
When you open the fuel cap of your 2014 ASX and hear a sound of air being sucked in, it could be due to the pressure difference between the inside of the fuel tank and the outside air. This is usually normal and can happen because the fuel system is sealed to prevent fuel vapors from escaping. If the sound is frequent or you're experiencing other issues, it might be a good idea to have it checked by a professional.
The fuel tank cap won't lock? What's going on?
