Will it affect the air conditioning if the navigation clip breaks and falls into the air vent? Do I need to take it out?
Will changing the air conditioning vent show the temperature if it didn't before? Has any fellow car enthusiast modified this?
The rear air conditioning vents are not blowing cold air?
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
4Hello everyone! I need some advice. When I turn on the AC, only the driver's side vents blow cold air, while all the other vents (passenger and rear) blow hot air, and it's really hot. Even when I close the vents, the area around them is still really hot. I went to the dealership, and they said I need to add refrigerant.
5The front clip of the electric seat adjustment panel is cracked. Do I need to replace the entire assembly?
6For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
7Is anyone else experiencing the issue where the air conditioning vent actuator motor is broken and makes a clicking sound when powered on?
8How to remove the air conditioning vent louvers?
9Will it affect the air conditioning if the navigation clip breaks and falls into the air vent? Do I need to take it out?
10Is everyone's air conditioning vent working fine? I feel like there's not much airflow to my feet...
