حسين هاشم
2024-09-06 13:21
Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
علي فرج
علي فرج2024-10-11 09:13
Electronic sound, both when pulling and releasing.
أحمد جم
أحمد جم2024-09-18 14:25
I have the same question. So do I.
Today, when I started the car, there was a "da-da-da-da" sound. After turning the engine off and starting it again, the sound was gone. This has happened twice. Not sure what the cause is.
When I start my Cayenne, I hear a "thud" sound. How did you guys resolve this issue?
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
Is it normal to hear a squeaking sound from the engine while idling when sitting in the cabin?
My 10-year-old 1.6 manual Peugeot 307 sometimes makes a sharp "squeak" sound, like metal rubbing against metal, when I'm shifting gears, releasing the clutch, or letting off the accelerator. Does anyone know what might be causing this? 🥲
2010 Peugeot 307, automatic transmission. Why does it make a squeaking sound every time I accelerate at low speed and then suddenly release the accelerator?
When the trunk of the Peugeot 301 is opened and then closed, the dashboard makes a ticking sound, similar to the sound of hazard lights. Does anyone know why this happens?
When I put my 2019 GA6 in drive, there's a motor sound like a "squeak," but it doesn't happen in reverse. Is this normal, and do you have any ideas about it?
When starting the Santana 1.5 automatic Trendline, the auto start-stop makes a squeaking sound. Does anyone know what's going on? Thanks, everyone!
Jeep Jeep Compass
Jeep CompassAED 89,000 ~ 115,000Gasoline & Petrol
