When you brake and see white smoke coming from the left side of the hood, what could be the problem?
My 2018 automatic car with a turbo is losing engine oil. I've checked with the service center; there's no blue or white smoke from the exhaust, and there's no sign of oil leakage on the engine exterior. Both the oxygen sensor and spark plugs are clean. The service center couldn't find the problem. Anyone knows what might be wrong?
The steering wheel of the 2016 Crossover Yizhi is not aligned properly and is tilted to the left. The left side is further from the driver, and the right side is closer. Has anyone else experienced this issue, and is there a solution?
08 Accent, ABS and brake lights are on. But the car seems fine. What could be the problem?
4Hey guys, I just got my Es2000 recently, and there's a clunking noise when I brake. It seems to be coming from the brake calipers. Do any of you have the same issue?
5What could cause a Peugeot 207 to sway from side to side while driving normally?
6Is the hood of the Grand Cherokee lower on the right side? When sitting in the driver's seat and the passenger seat, the hood seems to have different heights. From the passenger seat, the right side of the hood appears to have a greater curve, but from the driver's seat, the left side doesn't seem to have as much curve as the right. The car is parked on level ground, and the seats are adjusted the same, but the issue persists. However, when viewed from outside the car, there seems to be no problem. Is this a visual perception issue?
7Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
8The high beams of the car are not illuminating the road but are pointing to the sides. What could be the problem and how can it be fixed?
9Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
10What could be the issue if the left side mirror of the 2019 GAC GS5 doesn't fold?
