What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
The power light on the right dashboard is on, what does this mean?
Dear fellow car enthusiasts, my Kaiyi X3's dashboard is showing a yellow triangle with an exclamation mark inside. Has anyone encountered this? What might be the issue?
Hey folks, my Suzuki SX4 has a yellow OIL light with a little wrench under it on the right side of the speedometer. What does it mean?
4The dashboard lights keep staying on after turning off the engine recently, and I can't lock the car. Then, when trying to start again, it takes three or four tries to get it going. After starting, the dashboard lights come on again. When the dashboard lights are on, pressing the remote to lock the car doesn't work at all. Locking the car feels like a lottery every time.
5How to use the Sportage 4WD? Why is the yellow chassis light on the dashboard flashing? Thanks.
6What does it mean when the brake light on the dashboard is always on?
7What does it mean when a yellow exclamation mark appears next to the start-stop light on the dashboard after sudden braking?
8The car was fine when I parked it, but the next day when I started it, the engine fault yellow light came on. The car runs fine, but the yellow light stays on. It's been almost two years; does anyone know the reason? 😢
9I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
10When braking, does this taillight light up? After the dashboard is powered on, all the fault codes light up, but they all disappear once the engine starts. Is this situation normal?
