Is it normal for the 2019 Jeep Compass 1.3 to have the engine oil level drop to the bottom after 60,000 km and 7,000 km since the last oil change?
Does the 2012 Jeep Compass with a 2.4 engine consume oil or lose oil?
I last changed the oil in August last year and have driven less than 10,000 kilometers since then. Do I need to change the oil now, and what's a good type to use?
Should I change the transmission oil for a 2019 GAC GS5 270 Premium Edition with 60,000 km?
4Can the original engine oil of the 90 Zilong Edition last for 10,000 km before needing a change? Changing it every 5,000 km seems too frequent.
5Is it necessary to fix the issue if the oil level drops to the lower limit on the dipstick after 5,000 kilometers? Why is there oil leaking from the pipe and turbo area at the back? Has anyone else experienced this problem? The mechanic suggests replacing the oil separator. The car has 60,000 kilometers.
6Hey fellow car enthusiasts, my car seems to be burning oil. After about 7000 km on full synthetic oil, the dipstick shows it's almost at the minimum level 😭. This has happened in the last two maintenance sessions. It's a 2017 Jeep Compass with 120,000 km over 6 years. Has anyone else experienced engine oil burning, and how did you resolve or repair it?
7Does the 2019 Jeep Compass support CarPlay, and does it require any setup?
8Is there a second-hand 2019 4WD Jeep Compass 1.3 for sale?
9Does the transmission oil of the Jeep Compass 1.3T need to be changed? The manual says it doesn't need to be changed.
10Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
