خالد شاكر
خالد شاكر
Feb 16
Is it normal for the 2017 Jeep Compass 1.4T 2WD Family Enjoyment Edition to occasionally make a "thud" sound when shifting into reverse or forward gears? It seems like it's coming from the transmission. Has anyone experienced something similar?
Comments( 12 )
حمد حسن
حمد حسن2024-10-21 11:43
I had the same issue. How did you finally resolve it, mate? [rose]
سعود يونس
سعود يونس2024-07-11 19:20
It's okay, clutch issues are common problems.
نايف فايز
نايف فايز2024-07-09 10:53
Is it possible that the electronic parking brake wasn't released? Just asking. [I need a moment]
حكيم سعود
حكيم سعود2024-07-07 22:15
Features of the Jeep Compass dual-clutch transmission, don't worry.
نايف طل
نايف طل2024-07-04 22:11
When reversing with the 2019 Jeep Compass 1.4T, there's a "thud" sound, but it's fine in forward gear. Sometimes it doesn't happen. Does anyone know what might be causing this?
حسين ميثا
حسين ميثا2022-06-10 23:48
Same situation, how to solve it?
فهد حمد
فهد حمد2021-07-03 18:48
The transmission issue is normal for Jeep, there's no solution.
شهيد أحمد
شهيد أحمد2021-02-22 13:47
Hey bro! I have the 2017 1.4 Family Edition, and I'm experiencing the same issue as you! Sometimes when I shift gears, there's a loud "thud" that scares the heck out of me. I thought something might have broken!
20
سلمان عابدين
سلمان عابدين2021-02-22 09:12
That's normal. It's because you parked on a slope. Next time, when parking on a slope, switch to N, engage the electronic handbrake, and then shift to P. This will prevent it from happening.
عبدالله فاتح
عبدالله فاتح2021-02-22 08:32
When my wife drives, there's occasionally a crunching sound when shifting in low gears, and it seems to come from the gearbox. This doesn't happen when I'm driving, so I'm not sure what's going on.
Hi everyone, I need some advice. I have a 2011 Volvo S40, and after parking, when I shift from D to P, I can't remove the key. I have to restart the engine, reverse, then go forward, and try parking again. Sometimes it takes several tries before I can remove the key. Is this a transmission issue or something else?
I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
Whenever I used to brake, my Land Cruiser would occasionally emit a beeping sound, similar to the reverse radar sound. Recently, it happens every time I brake. Does anyone know what the issue might be?
When turning the steering wheel all the way to the right while reversing, it feels like the wheels are rolling over something, with an up-and-down sensation, similar to the feeling of an uneven tire.
I'm selling my 2014 Jeep Compass, used for family purposes, never been in an accident, well-maintained, and in great condition. Anyone interested?
The air conditioning in the 2017 Jeep Compass Automatic Family Enjoyment Edition sometimes has varying airflow, what could be the issue?
My 2019 Jeep 1.3T Renegade has over 73,000 kilometers. When I release the brake in reverse on a slope, there's a muffled "bang" sound with a sense of impact. It occasionally happens on flat ground too, but the sound is much quieter. Can anyone tell me what's going on here?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
I have a 2019 Jeep Compass 1.4T. When I put it in reverse and give it gas, there's a "thud" sound sometimes, but not always. Does anyone know what's going on? I checked with a mechanic, and they said it's normal for a dry dual-clutch transmission. Can anyone confirm this? Thanks.
I've got a 2022 GTS with over 10,000 km on it, and I've noticed an issue. When I turn the steering wheel all the way while moving forward or reversing, there's sometimes a loud noise from the chassis. It sounds like something is stuck or like a brake squeal. Has anyone else experienced this?
Jeep Compass
Jeep CompassKWD 7,777 ~ 9,395Gasoline & Petrol
