I washed my car and then the reverse camera went black. What should I do? Also, when I turn the indicator on and off, the central control screen sometimes turns blue, but it recovers after a while. What could be the problem and is there a solution?
Does the 2012 Sportage GLS have a reverse camera? Sometimes when I reverse, it shows "searching for signal," and other times the central screen doesn't change.
Which one is more expensive, the T8 in blue or black? And which looks better when driving, the black or the blue? I want to gather some opinions before making a decision.
How can I replace the central screen? Any recommended solutions? I use an Apple phone and hope to use CarPlay. Also, if I replace the central screen, will I lose the reverse camera function?
4The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
5I'm looking to install a central control screen with a reverse camera on my 2014 Peugeot 301. Any recommendations, fellow car enthusiasts?
6Is there any solution for the frequent freezing, black screen, or stalling of the central control screen in the Jetour X70?
7The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
8The screen went black, what's the issue? Anyone knowledgeable about this?
9I feel like the reversing camera image is not clear. Can I replace the camera individually?
10When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
