How to fix the issue of the gear position light not illuminating sometimes for the '21 model Compass when in Reverse (R) gear?
The gear shift light for the 150 isn't on. Could it be because a button wasn't pressed, like the ones for P, R, D?
The gear shift light for the 150 isn't working. Could it be that a button hasn't been turned on? The P, R, D indicators don't light up at night when the car is running.
Hey guys, I have a question about the 2006 Peugeot 206 1.6 with the semi-automatic transmission. When I put it in reverse gear, the reverse lights don't come on. What could be the issue?
4Do you have any tips for fixing a car door handle that sometimes doesn't return to its original position after being pulled?
5The air conditioning in the 2017 Jeep Compass Automatic Family Enjoyment Edition sometimes has varying airflow, what could be the issue?
6The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
7Gear position not displayed, a constant line, and the reverse radar is not working.
8How to fix the issue of the gear position light not illuminating sometimes for the '21 model Compass when in Reverse (R) gear?
9There's a noise when the car is in reverse gear, you can hear a creaking sound, but there's no issue in forward gears.
10Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
