Hey fellow car enthusiasts, my car seems to be burning oil. After about 7000 km on full synthetic oil, the dipstick shows it's almost at the minimum level 😭. This has happened in the last two maintenance sessions. It's a 2017 Jeep Compass with 120,000 km over 6 years. Has anyone else experienced engine oil burning, and how did you resolve or repair it?
How to check the transmission fluid dipstick: Is it normal for the fluid level to be almost one notch above the maximum hole when the car is cold?
4Second maintenance hasn't reached 5000 km yet. Should I use the complimentary oil or switch to synthetic, guys?
5I've been driving a 2009 Kia Sportage manual GLS with 120,000 km on it. I've always used 5W-30 engine oil, but recently it seems to be burning oil a bit. Should I switch to 5W-40 oil for maintenance? Has anyone experienced this before and can share some insights?
62020 top model, currently at 120,000 km. Started burning oil shortly after changing the belt at 100,000 km! Anyone else experiencing the same issue? 🤦♂️
7Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
8What type of engine oil should I add to my Prado 2700 that has run over 180,000 kilometers but doesn't burn oil? Thank you, everyone!
9Do you use fully synthetic or semi-synthetic oil for your 10,000 km oil change?
10How to deal with oil burning? Today, while driving over a bump, the car jolted and the screen displayed a warning: "Low oil pressure, please stop." The warning flashed briefly and disappeared when I returned to a flat road. When I checked the dipstick, the oil level was very low. I just had maintenance done 1,000 kilometers ago. How should I repair this situation with a 1.6 naturally aspirated engine?
