Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
Has anyone encountered engine noise in a 2019 F150 with 60,000 km? The mechanic says it's a common issue and suggests dismantling the engine to fix the gears.
Is it true, as other car enthusiasts say, that the Ford F150's transmission has severe jerking issues while driving?
Is the fuel consumption of the 1.8T GA6 high or not? Some people say it's high, while others say it's normal!
4Should I change the transmission oil for a 2019 GAC GS5 270 Premium Edition with 60,000 km?
5What maintenance is needed at 60,000 kilometers?
6Does the 2019 model with 1.4T engine need a transmission oil change at 60,000 kilometers? Some say it's maintenance-free, while others say it needs to be changed. I'm not sure what to do. Have any of you changed it?
7What maintenance is typically needed for a 60,000-kilometer major service?
8Does the transmission oil of the Jeep Compass 1.3T need to be changed? The manual says it doesn't need to be changed.
9Why do some of the new Prado models have a rear spoiler while others don't?
10Hey car enthusiasts, has anyone never changed their CVT transmission fluid? Mine's been 6 years and almost 80,000 kilometers. I'm not sure whether to change it or not. Some say you don't need to, and changing it might actually cause problems. But I'm also worried about not maintaining it properly. Any advice?
