خليف أحمد
2024-01-27 17:40
2017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
نايف فهد
نايف فهد2024-04-22 23:07
Mine's a bit better, shifting to 2nd gear at 2500 RPM in manual mode feels a bit jerky. [I want to be alone] [I want to be alone] [I want to be alone]
حسن أيوبي
حسن أيوبي2024-01-30 02:56
Use manual mode.
حسين فؤاد
حسين فؤاد2024-01-28 07:21
Cold car won't shift gears, needs to reach 1000 RPM when warm to move.
Why does my 2008 imported Mazda 3 hatchback idle at 1200 RPM during cold starts, while it's usually at 1000 RPM? How can I fix this?
Is it normal for the Yizhi to have an RPM of 2500 during a cold start in the morning?
Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
When I floor the accelerator on my 2.0T model, the RPM only goes up to 3000 and won't go any higher. Is this normal for everyone else's car too?
Has anyone experienced their car's tachometer suddenly jumping above 3000 RPM and then dropping back down while driving?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
At 120 km/h, how many RPMs does your Honda City engine run at? Mine goes over 3000 RPM. Is that normal, and how can I fix it?
When I start my 2021 Outlander, there's a popping sound in the engine bay during cold starts, but it goes away once the temperature rises. Has anyone else experienced this?
Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
Jeep Jeep Compass
Jeep CompassAED 89,000 ~ 115,000Gasoline & Petrol
