فهد عباد
فهد عباد
Sep 10
Why is my Toyota Coaster stalling after running for an hour and then restarting? I have to wait for the engine to cool down before it can run normally again. Does anyone know what might be causing this issue?
طلحة محمد
طلحة محمد2019-09-11 19:09
Replace the camshaft sensor.
أحمد سعود
أحمد سعود2019-09-11 15:10
This car has issues, just switch to another one.
قابوس محمد
قابوس محمد2019-09-10 22:48
There's an issue with the fuel pump. Just replace it, and it will be fine.
علي فريد
علي فريد2019-09-10 22:24
This situation is mainly due to the significant impact of high temperatures on related components. The most directly related factor is the fuel. High temperatures cause the fuel to evaporate quickly, which can affect the fuel pressure and create vapor lock, leading to difficulties in starting the engine.
I bought a 280 Sharan in October 2017, and it has run 38,000 km. Recently, I've noticed that the car stalls and restarts twice when auto start-stop is active. It happens when I stop at a red light; the car auto-stops, then restarts, and soon after, it auto-stops again and immediately restarts. This doesn't happen very often, only twice this month, and otherwise, the car runs fine. Can anyone advise on what might be the issue? Should I take it to the dealership for a check-up?
1.5T manual transmission, 2016 model, 50,000 kilometers. Spark plugs were replaced at 42,000 kilometers. Today, the car suddenly stalled, and after restarting, it stalled again after driving for a while. Can any experts help figure out what the problem might be?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
Does anyone know why my 2014 Touran, which has 140,000 km on it, sometimes has the D gear light flashing while driving and the accelerator doesn't respond? I have to turn off the engine, switch to P gear, and restart the car to drive again. What could be causing this?
Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
Hello everyone, my Peugeot 307's air conditioning isn't cooling, but sometimes after restarting, it cools again. What could generally be the problem?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
I got a 2021 Murano in July 2021, and just recently on a long drive, I found that the AC was blowing hot air with no cooling. After visiting the repair shop and refilling the refrigerant, the AC started cooling again. The car is just 3 years old, is it normal for the refrigerant to run out so quickly, or could there be a leak?
Toyota Coaster
Toyota CoasterOMR 20,900 ~ 24,656Diesel & Gasoline & Petrol
