محمد ياسين
2024-07-31 09:37
Where is the VIN (Vehicle Identification Number) stamped?
حسين نوح
حسين نوح2024-08-31 00:42
On the right front wheel beam.
I'm not sure where the VIN is located on the Toyota Sequoia's frame.
Where do I find the engine number for the vehicle inspection today?
Where is the engine number located?
You have a 2016 model with a CVT transmission, but you're not sure which version it is. You can usually find this information in a few places: 1. **Owner's Manual**: The manual that came with the car often lists the specific version or trim level. 2. **VIN Number**: Locate the Vehicle Identification Number (VIN) on your car and use it to check online databases or contact the manufacturer for detailed information about your car. 3. **Door Jamb Sticker**: There is often a sticker in the driver's side door jamb that includes details about the vehicle, sometimes including the model version. 4. **Service Records**: Check any service or maintenance records you have for your vehicle, as they might list the specific model version. 5. **Dealership**: Contact a dealership with your VIN number, and they can usually provide detailed information about your car.
To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
My car was involved in an accident in 2018, affecting the front bumper and radiator area. It was repaired at the 4S shop. For the past four years, there were no issues during the vehicle inspections. However, this year, the inspection technician said that the vehicle identification number in the engine compartment had been altered. What's going on with this?
Toyota Toyota Coaster
Toyota CoasterAED 193,200 ~ 220,500Diesel & Gasoline & Petrol
