Can the gear ratio be changed?
Can the GA8 dashboard change themes?
How often should the gear oil be changed for the Rapid?
Is it necessary to change the transmission fluid for a 2010 Suzuki SX4 Hatchback 1.6 Automatic that has traveled 160,000 kilometers and hasn't had a transmission fluid change yet? The gear shifting is currently very smooth.
4Can the gear ratio be changed?
5Car enthusiasts: Can you please advise, do you have to be in the P gear when turning off the engine for the Changan? Can you park and turn off the engine in the N gear and then switch to P gear? Thanks!
6Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
7Can the Xubao logo be changed to a red one?
8Car enthusiasts, do you think that by changing the gear ratio and using 95 octane fuel, there's a chance to reach a top speed of 190 km/h? 😁
9Can I change to a non-CVT transmission?
10There's a noise when the car is in reverse gear, you can hear a creaking sound, but there's no issue in forward gears.
