The car is a 2015 model and has run 99,000 kilometers. The warning light turned on, and you replaced 4 ignition coils and 4 spark plugs. After some time, the light came on again, and the engine shakes when starting, but it's still drivable, though the light remains on. What's causing this issue?
The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
4The dashboard reported low transmission performance, and then the car wouldn't accelerate. After restarting, the warning light went off and it drove normally. What could be the reason? (The onboard computer cleared the fault light, but it came back on before I got home.)
5The Check Engine light on my JETOUR X70 with 40,000 kilometers suddenly came on.
6After the light came on, I drove 20 kilometers and then refueled 65 liters. I'm starting to doubt if my fuel tank is actually 80 liters.
7Today, while driving, the engine warning light suddenly came on. No other lights were on, but I felt the engine trembling and it lacked power. After driving for about 150 meters, during idling at a red light, the engine vibration was quite noticeable. When the light turned green and I accelerated, the trembling became more pronounced and it lacked acceleration. I pulled over immediately, waited for about 10 minutes, and after restarting, everything was back to normal. I restarted a few times afterward and everything was fine. The last time I started the car, I drove a few kilometers home and it was normal too. Has anyone experienced this issue? Does anyone know what might be going on?
8The EPC light came on twice, but restarting the engine fixed it, and it hasn't appeared again. Fellow car enthusiasts, what could most likely be the issue?
9I drove for about an hour at night, and the battery warning light came on. Then I stopped driving. The next day, when I drove again, the warning light was off. Can you tell me what's going on and if it's serious? Thanks.
10The car won't start, and the EPC, battery, engine, and malfunction indicator lights are all on. What could be the reason?
